Main Light Switch
    Main Light Switch
    MK11 Stag, 76. Can anyone provide advice to help remove the main light switch from its plastic knob. I want to follow the excellent article on it overhaul, but that misses out on this special bit!
    Are you talking headlight or cabin light ??
      From the early ROM (Mk1):
        same as in 1977 ROM
          Hi,
          I have a Mk I but there is no allen screw in my light switch.
          It has a spring loaded lug.
          So, you just use a drill bit (or similar) to push into the hole and compress the lug, whilst gently withdrawing the knob,
          Den
            Originally posted by DZP View Post
            Hi,
            Den
            Hi,
            Can you suggest where to drill the hole to push in the springloaded bearing?,its not very clear
            Thank you
              Technical note now updated to include this
                Originally posted by maverick View Post
                Hi,
                Thank you
                If you look at the technical note you will see on a couple of pics that the hex shaft where the Bakelite knob fits onto has a small spring loaded ballbearing. The knob has a hole and, when pushed onto the shaft, that spring loaded ball jumps into the hole to secure the knob. The "drill" just refers to a piece of stiff wire or similar which you insert into said hole. Then push down the spring loaded ball and simultaneously pull off the Bakelite knob.
                When you re-assemble, make sure that the hole aligns with the hex surface where the spring-loaded ball is, otherwise the knob won't be retained on the shaft.
                I seem to recall that the original Choke knob is retained in the same way.
                  The hole is already drilled and is what the lug locates into.
                  I managed to find a picture of my switch before i cleaned it up.
                  see attached.
                    Ahha. Thanks very much, all of you! I have the hole located and have had the choke cable knob off when the dash got rebuilt. If this is the same, its just a case of persuasion!
                      Thank you
                        see attached.
                        Cheers DZP
