Hi all, apologies if I am bombarding with questions, but everyone here is being so helpful, trying not to abuse it !
In my last post (apart from sparking a 'which colour is best' debate by mistake!), I mentioned the starting problems with my new / oldStag. oddly enough it decided to start first time today, ran perfect, slowly coming off choke, I dropped the revs right down before hitting a gear so I didn't get spinal damage, and actually got out of the garage, turned it around and parked on the drive. It started several times no problem, and ran fine. This was a momentus moment. It then decided for no apparent reason to go straight back to refusing to start, end of momentus occasion! Still at least I can now look at it from the front for a while in the garage now! Even after leaving it for 20 mins it was no different - I am still suspecting the coil and ballast resistor so will get them done this weekend.
Round 2. Cooling and my Stag - I expect there may be some good knowledge on this one!
When I got the car the previous owner had experienced an overheating problem. He had the heads off as it had blown a head gasket (they had been done just a few months before and equipped with H/D gaskets), it also has a Kenlowe kit- I don't know if he had them skimmed or not etc. I am trying to get hold of him to find out. When he put it all back together he found it was 'still pressurising the cooling system'in his words. I have never run it up to temp as I want to see if I can find the problem first rather risk blowing head gasketagain (assuming it's not already gone!). A friend with a Stag has looked over it and we were thinking it could be a blocked rad. I am going to have this checked out but decided to take the rad out today and was both suprised and bemused at the outcome. I removed the bottom hose and got about 2 litres of crystal clear tapwater out. The expansion tank has the usual nasty rusty coloured water in! After just 2 litres of water coming out from the bottom hose all dripping stopped. I lifted the rad out and when I tilted it, about another litre came out (half of which was on me!), then, I moved it through 360 degrees and got about half a litre of fresh water with red antifreeze from it! Having a combination of clear water from either the rad or bottom hose, red antifreeze in the rad (very little) and grim rusty water in the expansion tank suggest to me this stuff has not been moving round much!
Daft question probably, but I am concerned by the 'clear water', and assume about 2 litres would have come from both the rad and bottom hose - does this sound about right? I've got not sign of water in the oil, (and no sign of fresh oil after the heads coming off), there is no sign of contamination anywhere and I ran it without the dipstick and there is no signs of pressurising the case either, but when I ran it as soon as it starts to warm up things don't smell to pleasant in the engine bay! But I am not 100% happy that it is not just burning off oil from a possible small leak somewhere, its pretty grubby and oily down the right bank. I just feel that something has got to be causing this and the attention may be more on the effect than cause - the top hose had no coolant at all.
Any thoughts and ideas would be appreciated, if the heads have been done and are not at fault I don't want to rip themboth off for no reason.
PS - tracking history is interesting, Tony Hart confirmed they have reconned it back in 1983, and serviced it later (27 years ago and they have it on record - impressive!).
Thanks, Mike
Thanks, Mike
