Just when you think everything is going ok another issue raises its head
Took the Stag out at night for the first time since rebuilding the engine. Up until now only been out during the day in case I broke down!
I noticed that once it started the ignition light was glowing very dimly which got dimmer the higher the revs go. I'ts a new alternator and I checked the belt which was tight. I have an external water pump so the alternator is the other side of the engine. I'm assuming its a resistance problems due to the extended loom but could be wrong.
I'm planning to clean up all the connectors from the alternator back to the ignition light to see if that helps. Is there anything els it could possibly be ?
I could just drive it during the day as you can't see it glow then
