Hi all hope you're all safe and well. I have a jag ZF gearbox fitted to my stag. Those of you who also have one fitted know that the Auto selector foil does not align with the appropriate gear. I understand that there is available a foil that can be fitted to correct this. Any idea where I can purchase one, please. Thank you
Mr Jag ZF gearbox Foil under auto selector
They were produced by a member of this forum, who kindly posted details in the Technical Section under Powertrain: https://www.socforum.com/forum/forum...4-speed-legendDave
image_43786.jpg Also available on Facebook files in the stag fan club.
these are files for DIY printing.
However, if required I can post a few out. (FOC)
Be nice to see pics of them fitted.
pm me with your address if you need them posting.
ATB
Julian.
attached is a photo of the sheet with backlight green .
also available for 3speed too.Last edited by jbuckl; 27 February 2021, 23:31.
- Likes 1
Originally posted by jbuckl View Postimage_43786.jpg Also available on Facebook files in the stag fan club.
ATB
Julian.
also available for 3speed too.Paul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
Originally posted by Goldstar View Post
What did you print them onto Julian?
printing double sided gives the green backing.
if you struggle to make your own with the files just pm me & I’ll post some ready to glue into a new blank.Last edited by jbuckl; 7 May 2021, 22:23.
Originally posted by Phil S View PostI have printed this out for my zf, laminated it and fixed it on top of the existing logo, after scraping the print off the rear of the selector ,if that makes sense seemed the most logical and easy fitting method, still not perfect alignment but better than it was
It wasn’t intended to be added to an original surround that has the 3 speed legend.
The alignment of the arrow to the legend can be anywhere from way off to perfect, depending on quite a few variables, much like the original one.
Variables include the linkage position, the surround position, the way it’s been glued in etc.
if posting I usually send 2 or 3 for trial and error.
the spacing of the gear indicators is determined by the size of font & available space. The distance is even.
they are only ever intended to give an indication.
Would be nice to see some pictures of successfully installed legends.
would be possible to remake the surround with the legend molded in, but I’m not sure there’s much of a market for those.
