Lower wish bone bolt
    Hello everyone, just thought I would share this with you, on putting my front suspension back together again, I have found a way of getting the lower wish bone to drag strut bolt fitted with the nut at the bottom, the right way up. When the car is jacked up undo lower wish bone where it goes into cross member remove bolt and drop, pull the wish bone down and bolt drops straight in. Then just push lower wish bone up and push bolt back in. If this has been sujested before I apologise. Cheers Steve.
    See this thread for another solution.
    Today I tried to remove my drag struts in order to replace the subframe attachment bushes (for increased caster angle and improved steering) but the front strut fixing (to the wishbone) has been attached with the nut at the bottom and I cannot withdraw the bolt upwards far enough to release the drag strut - it hits the spider
