Steering column.
    Steering column.
    Hi chaps, just a quick one. The part that the steering wheel bolts on to, I can’t work out how that comes off, I am wanting to replace bearing underneath it. Any help gratefully received.
    Many thanks Steve
    Have you got a copy of the Repair Operations Manual? It is section 57.40.
    Download a copy here: http://www.grampianstags.net/Stag%20...n%20Manual.pdf
      Hi DJT, yes I have a copy but couldn’t find what I was looking for. Many thanks Steve.
        there are two bearings. are you sure they need replacing. folks use a modified ring clamp to remove the play in the column.
          Hi Sujitroy, yes I’m going to order ring clamp and try that first, in and out movement was stuck solid managed to free that and cleaned,so going to replace those bushes to have that movement back.Many thanks for reply. Steve
