I have removed the old calipers and have a new set to fit (new discs fitted). Problem I have is I just can't get the new calipers to line up with the holes without the disc shield getting in the way.
The calipers are a really tight fit, I'm talking wood block and hammer to slide them into place, I've measured the old caliper lugs and not much in it but the new caplier lugs are a little thicker which is not helping.
Problem is that as the caliper is being driffted into place it drags the disc shield lug across the bolt hole. I can just manage to lever that across, but it takes the caliper lug with it, move the caliper and the shield covers the hole again.
I've managed to get the lower bolt in place so I know the top lug is in the right plane and just a case of moving the caliper in/out to line up, but this shield won't play ball.
I have managed to get the top bolt through the caliper lug to stop it moving, but after levering the shield it tightens up on the bolt because the caliper moves, tap the caliper to free the bolt, moves the shield.
Not sure what is going to run out first, swear words or patience.......
