External Water Pump Second Bleed Point
    I'v just read notes on the external water pump from Stagdad. I brought my stag with the same pump fitted which was why I was interested in the article. In the filling section it states: 'Open two new air bleeds and make sure the heater valve is also open then slowly fill radiator through top of rad.' Could you tell me where the lower or other bleed is, I can see the top bleed point but I didn't even know there was a second one. I am about to drain and flush the system so it would be handy to know where the second bleed is.
    Thanks for your help
    Rick
    I have fitted this mod to my car, there is only one additional bleed valve added and this is at the back of the RH cylinder head (viewed from in the car) by the heater inlet. If you want a copy of the kit fitting instructions them PM me and I can sent them over to you, I'm sure Steve won't mind as the kit is already fitted to your car.
      Thanks for confirming that for me Roy, I thought that was the case but it was only when I read the Heating/cooling post by DaveB in the Technical Guides where he mentioned opening two new air bleeds that made me think I had missed one. I have downloaded the kit fitting instructions thanks and needless to say I didn’t find a second bleed in those either
      Thanks a lot for your help
      Cheers Rick
