I removed my inlet manifold on Stag no.2 to take care of a leak. The block has been drained from the engine drain plugs. I notice something shinny between the block and head. i got a paper towel and fed it through the small gap. it is wet. I am unsure why it remains wet as the block is drained. I rebuild this engine with new Payen gaskets and did not apply any sealer. The leak is between two pistons. I have a spare block and can see the water galley is right there. The head stud is right by there too. I have not driven the car much since rebuilding it. However I have retorqued the heads. Can I clamp the head down further? Currently the heads are torqued to 65 lbs. If this is not recommended then the head will come off again. I have another stock Payen gasket, but will use some sealer this time or I could get the BGA thick gasket with some sealer to hopefully take care so some imperfections on the block face around the water passage. Any other recommendations?
Sujit
Sujit
