What coil?
    What coil?
    What is the correct coil for a stag fitted with standard Optronic Lumenition and original engine, all the supplier sites list different coils I am completely confused! Please help.
    Most modern Lucas stuff is rubbish. Many on here have gone for a Bosch Red coil, part number 0221119030. Available from Burton Power, Opie Oils or elsewhere.
    The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILS
      TRO.
      The electronic ignition does not require a special coil. You still use the standard Ballast Resistor type as fitted to all Stags, but get a good one from a good supplier as there is loads of rubbish about.
        Fited one of the Bosch coils a while back, works perfectly, more so than the 3 previous (non Bosch) ones ever did.
          What about the Flamethrower, I had it on my red Stag with Luminition and 10mm leads.
          http://www.americanmotorfactors.com/..._II_Coils.html.
            Recently used a vixen dry coil. Seemed to improve starting.
            2.
              Where did you get it from, please.
                + 1 for Bosch red with lumenition and ballast in tact. long story.
                if u have the ballast in tact and plan to stick with the old classic lumenition. don't got for a flame thrower. I bought a 1.5 ohm one and the document says to remove the ballast. lumenition needs a combined resistance of 3 ohms. I went and bought a 3 ohm first thinking I would do away with the ballast. the package says 3 ohm ones are not recommended for 8 cylinder cars.
                go figure. hence Bosch red
                  Will a Bosch Red Coil be ok fitted with Petronix Ignitor1?
                    Search the forum on this topic: Pertronix ignition for Stag
                    I have Pertronix on Stag no. 2 with a 1.5 ohm pertronix coil and no ballast.
                    Buy the ignitor II, 9LU-181A. and not the LU-181A the lter part no. is an older version.
                    Sujit
                      Works perfectly well on mine with the Pertronix fitted inside the distributor (dizzy overhauled by Distributor Doctor) and the original ballast wire. Starts first time, every time........... until now that is
                        as Dave said Bosch red coil works well for me
                        Parts recommendations - Stag Owners Club Forum (socforum.com) see post 8
                          Sujit
                          Got mine from Distributor Doctor a few weeks back. He gave me the Ignitor 1 as per recommendation. Mind you it was very expensive!
                            The igniter one can get fied if the ignition is left on. that's why they came out with the 2. here in USA they area bout 100$ ish.
                              Sorry it was not vixen it was viper :- https://www.google.com/amp/s/simonbb...-DLB105-SILVER
                              still using the ballast (resisted wire replaced)
                              with Aldon igniter in distributor ignition switching / trigger)
                              fires & starts from cold in less than a turn or so it sounds.
                              2.
