diff extension bearing
    Hi just bought a diff from robsport and I’m going to refurb the diff extension, I’ve bought a new bearing but was wondering if this will be a inferior part as it was £14 plus vat does anyone know where I can get a robust bearing? ...thanks dean
    Chris Witor or LD parts
    I made these notes
    Qill shaft bearing
    LJ7/8-2RSJ RHP Sealed Deep Groove Ball Bearing 7/8x2x9/16 inch RHP Deep Groove Ball Bearings (Inch) - Bearing King (bearing-king.co.uk)
    RLS7-2RS1 SKF Imperial Sealed Ball Bearing (LJ7/8-2RS) 22.23mm x 50.8mm x 14.29mm - BearingBoys
      Great response thanks I’ll have a look
        Originally posted by Dean View Post
        Hi just bought a diff from robsport and Iâm going to refurb the diff extension, Iâve bought a new bearing but was wondering if this will be a inferior part as it was £14 plus vat does anyone know where I can get a robust bearing? ...thanks dean
        You'll be changing that again in a year I'm afraid. You need to get a quality bearing - either of the ones Sujit mentions are good.
          Go SKF, no option.
          Cheers Ian A
            Are you uprating/strengthening the diff extension?
              Yes looking to get it strengthened, can you buy them already done or do you know where I can get the bits to weld myself
                Yes, you can buy them pre-done, LD parts used to do them. Probably others, too, sure other FMs will chime in.
                  I took mine to a local steel fabricator, payment was a contribution to the Tea break fund
                    Got my strengthened nose extension exchange from EJ Ward, with new RHP bearing. Outstanding service from them.
                    Jeff
                      +1 for EJ Ward great service
                      1973 Tahiti Blue, TV8, ZF 4 Speed
                        Look at post 17
                        Parts recommendations - Stag Owners Club Forum (socforum.com)
                          If you can weld, have access to a welder, either stick or mig, it's a simply job, just 4 pieces of flat steel bar. I've done both mine without any problems.
                          Cheers Ian A
                            Thanks Ian, I can weld but just ordered one from wards as it;s quite a reasonable price. . Getting a bit expensive now though Ive just had the tate and Lewis gearbox and have ordered a new 345 diff
                              Hi Dean, I to am running a 3.45 behind, a J overdrive. It makes the gearing high enough (hoon days over, well just about) hence having done both the 3.7 and 3.45 with SKFs.
                              Also rear is fully poly bushed with CCD CV half shafts and uprated outer bearings. A pair of Panhard transverse links. Self designed and fabricated. Gaz adjustable gas shocks. Stag goes like its on rails
                              Cheers Ian A
