Fuel pump looking for original SU part no.
    Does anyone recall if this is the SU part no. for the original SU fuel pump AUF 306?
    Sujit
    Says that in the manual.
      Thank you. I was given a from a fellow Stag owner, a pump labeled AUF 305 and another labeled AZX 1307 ,and from searches it appears these are for Jags and MGs. I plan to save these and use then with a pressure regular.
      Sujit
        I have a brand new pump, I accidently dropped it ( I am cack handed....left handed ) and there is a hair line crack in the area pointed in pic. Is there some way I can have it repaired ? There is a very slight seep of petrol from it once the bolt is tight. Bought from LDparts. Also I have another metal one that I damaged slightly .
          im cheap but get a new one.
            i just serviced two original su leaking pumps. with both pumps the cork gasket at the back hardened with age and leaked . what I also found with both pumps they leak between cover and paper gasket. some old pumps have a plastic membrain against the rubber diaphragm. I lifted that mebrain and applied hymolar and sealed back. So far no leaks from area. For one cork gasket didnt replace I used tiger seal. I also used tiger seal on my boot lid. the skin separated from the frame. all good stuff.
              Sujit
              That is the original part number, this was superseded by AZX 1307/8 and AZX 1311.
