Hi Folks
I am fitting new struts this weekend, I hope?
I have a new standard damper repair kit but the soft metal bush for the strut top mounting is too big.
I have been emerying the bush's slot and am getting there, but now the spacer is too big to fit in the bush. I suppose i will have to emery this too.
My original strut's (the oil filled version, would this mean it is original?) bush was seized in the mounting and so the damper rod was worn.
Am I missing something, is this normal? I have measured the top mounting hole diameter, and the bush when compressed is about 0.3 mm bigger.
) but when you have a rough idea what you are doing it is so much quicker than to go through the return process.
