The last issue I'm trying to solve before I can obtain an MOT hopefully,
So the original symptom was a lazy left indicator, and I took the opportunity to install led indicator bulbs all round, and replaced the flasher unit with a suitable earthed unit.
This solved the lazy flash but now, with sidelights on, when I use the indicators, all four indicators will come on (albeit the side not 'signalling' is dim). This happens signalling both left and right.
By process of elimination of removing fuses for each lighting circuit I have narrowed the issue to the left hand sidelight circuit. However removing the side and tail light bulbs makes no difference.
Investigating the rear light cluster revealed a bit of a rats nest where someone had wired in a towbar, so have removed all that and am happy that the wiring there is now as it should be. Nothing is obviously wrong at the front sidelight. The instrument cluster lighting appears OK too.
I'm assuming power from the sidelight circuit is 'feeding back' into the indicator circuit somehow, but am running out of ideas as to how? The light clusters surely are the only point where the sidelight and indicator circuits meet? Has anyone come across a similar problem?
I havent ruled out the new indicator relay being the issue, but if so why would it work ok in all other circumstances?
thanks
Kevin
thanks
Kevin
