Instrument wiring
    Instrument wiring
    Hi, according to this very helpful diagram , I am a bit confused about the fuel guage wiring.
    It states that the left wire is green and right wire is green. But thre are only green and i think blue wires, as is the case with the temp guage.
    I am in the process of putting in the clocks.
    • All views taken from the rear of each gauge.
      Voltmeter
      bottom left : double white
      bottom right : double black
      top : bulb holder
      Temperature Gauge
      bottom left : blue
      bottom right : greentop : bulb holder
      Clock
      bottom : purple
      top : spare?
      right : bulb holder
      Fuel Gauge
      left : green
      right : green
      top : bulb holder
      Rev Counter
      top : bulb holder
      bottom : black
      right upper : double green
      right lower : grey/white
      Speedo
      top : bulb holder
      bottom : black
      far right : single green
      middle right : double green
      right nearest centre : double green
      Warning Light Cluster
      simply refit the plug
      Dimmer Switch
      bottom : red black
      middle : red/white
      top : red/white
      In the end I did not use the info myself. I have fitted a Mark 1 dash in the car as the walnut in my donor car was mint and I prefer the look of a Mark 1's gauges.
      Bruce
      1973 GT6 Mk3 Pimento Red
      1974 Stag MOD,3.45 diff,French Blue, Fiat seats, Belt EWP, H/Tank
    The wiring diagram shows Light Green from the voltage stabiliser and Green/Black from the sender, and according to the ROM they can be connected to the fuel gauge either way round.
    Nigel
    This gallery has 1 photos.
      Nigel
      Great thanks,
