Cylinder head gasket
    Hi ,does anyone know the thickness of a standard stag cylinder head gasket, didn't get much help from the suppliers , the one I took off is 50 thou
    approx. std head gasket 40thou/ 1mm once it's been compressed. extra thick roughly 60thou/ 1.5mm once been compressed
      Saver shims are available should you need additional thickness - Stagweber and Gosnay Engineering.
        Thanks guys great help
          If you want to curl up in front of a fire and do some reading on head gasket thicknesses, just type "head gasket thickness" into the search box and you'll be sorted for an hour or so!
