Just replaced both Stromberg diaphragms and now the car will not even start! I had a slight misfire and 4 of the plugs had a lot of black soot so I replaced the diaphragms (both sides). Seems I have taken a step backwards rather than forwards! Any suggestions?
Replaced carb diaphragms and now won't start
Talking of backwards.. sure you got them in the right way round? There are small detents on the piston and the carb body that align with small tabs in the diaphragm. This needs to be correct or else the piston will not be aligned correctly.. could cause problems if it’s not right.
*edit. What Mike said while I was typing!
TerryLast edited by trunt; 25 May 2021, 23:11.Terry Hunt, Wilmington Delaware
- Likes 1
Check the fuel at the bridge; check with elbows and air filter off.Originally posted by Eric B View PostThanks everyone - Mike - yes the right hand carb was the one linked to the soot covered plugs. I'll retrace my steps to check the tabs are in alignment as suggested in the replies - I thought they were, and will see if that helps.
Thanks again
Eric
under & over fuelling easy to spot as the revs rise & pistons lift. Also easy to check carb piston rises and falls smoothly too.
block the vacuum take off for the thermac. The one way valve inside the take off usually leaks as the spring & ball corrodes.Last edited by jbuckl; 29 May 2021, 00:01.
I've recently fitted new diaphragms whilst replacing the metering needle adjusting screws and seals to fix oil loss from the dashpots. My new diaphragms were thickly coated in the white powder (some sort of chalk?) which I carefully wiped off before fitting. The car is running far more smoothly since the work.
