I am struggling with a recurring issue of coolant not returning from the expansion tank into the radiator after cooling. I move coolant back from the tank into the rad, warm the engine up with the rad cap off (I have also tried with the expansion tank cap also off at the same time), I wait to the air bubbles stop and then tighten everything up. But then after a drive, when I go to start the car the following day, the level in the expansion tank has risen towards the top (again, it has not returned to the rad). I have had a small leak from the left rear inlet manifold - when I pump 10 psi into the expansion tank I can see two different drips leaking onto the Vee. After pressuring this way, I also noted the level in the rad dropped a little.
Searching the forum it seems others have small leaks into the Vee, but don’t have the same issue as me. So, does that mean there must be an additional problem, as well as the inlet manifold? If, so what are the suggestions to test further? I am a bit nervous of changing the inlet manifold gasket as it seems this can be problematic, and I don’t want to make matters even worse!
Also, can someone confirm the normal level of coolant in the rad, after cooling down? If I remove the top brass plug (mark 2 Stag) should it be right to the top, or will flow still be ok if level with the bottom of the top-hose, or even a little lower?
