Radius Rod Washers & Bushes
    cupped strengthening plate coming soon!
      Hmmm, good question, not sure about that.
        Just need to know if there's a strengthening plate on the nut side too.
          Ok Drew thanks , good job bye the way
            Originally posted by MandM View Post
            The above picture clearly shows the cup washer which is welded to the chassis leg. It is worthwhile checking these as that area is a bit of a rust trap. When I stripped my car the nearside one was completely rotted away. They can be bought from Robsports. See pic below
            1978 Stag Brooklands Green
              During the checking did you by any chance have a look on the rear side of the chassis hole to see if there is also a doubler of some sort there?
                Originally posted by NeilR View Post
                Agree with DJT. Also agree with Robsport offering for the washers.
                Fitting them the wrong way round (Rubber bushes) allows the radius rod to wear the chassis hole oval - seen that a few times.
                Ive seen the radius arms with a wear groove in them but not seen the chassis hole oval
                Ive only had to repair the chassis hole, wear the radius arm ripped out of the chassis on one car,but that was mostly due to rust
                  There wasn't
                    OK, think we might have got this one licked now with all of the comments! Dunno about you, but I reckon this is the first time I've seen all of the components shown in their correct orientation - yeah SOC!
                      Should Robsports not have these repair cups in stock you can contact Lloyd Reed who manufactures them. lloyd.reed02@gmail.com
                        Post 24 looks spot on to me with the Robsport washers.
                        Just wish the chassis repair cup had been available when I needed one - had to fabricate one.
                          Thanks for all your effort Drew, don't think you would this sort of thing on FB recorded for all, thanks again
                            Proof of the pudding is in the eating. I ordered the Robsport washers and they arrived yesterday. Unfortunately - for the purists - their 134556 washer is no longer dished - it's more lke the Rimmers offering. On their eBay website it is still shown as truly dished like in the above pic in post 24, on their Shop website it isn't, and that's the one that arrived. The 134557 is good, with the smaller hole.
                            Drew
                              +1 I think drew should issue a re-written ROM
                                Already in work see 51.45.29 4. & 5.
