Problem 1 - Refitting Dashboard
    Evening All,
    Just had the windscreen fitted today (all went well, phew) and then tried to refit the dashboard which has caused me a headache. When the dash is pushed forward as far as possible and bolted up there is a large gap almost the entire width, it only touches the A post at each side. The gap is big enough to push a finger through and it doesn't seem to be fouling anything, not even the new screen rubber. I tried the old dash as well and that also didn't fit properly. Any ideas about what may be causing this?
    Regards,
    Mark
    1972 Mk 1 - Sapphire Blue; Original TV8; HID Lamps up front;
    There is a trim piece at the rear of the dash that covers this gap.
    Phil, Mk 2, 1974 Emerald Green, Auto, (HT & Kenlowe Fan)
      I just fitted mine yesterday and have ended up with a few mm (5 max) gap between the demister outlet finishing strip and the windscreen rubber. The fixing holes in the ends of the fascia are elongated and I checked that I had heaved the fascia as far forward as the holes permit, but still ended up with this small gap,
        I had the same gap and found a sealing strip in black that filled it neatly
        Car Rubber Sound Seal Strip 1.6M U-Type Dashboard Edges Sealing Strips UK STOCK | eBay
          Hi Guys,
          Thanks for the responses. I pre-fitted the demister vents and finishing strips to the dash as they can be a bugger to fit after the dash is in situ so there is no more trim to fit that might cover the gap.
          Dickr - can you post a photo of the sealing strip in situ ? Thanks again.
          Mark
            Mark, it is a tricky area to photograph, but this one shows a section quite clearly IMG_4988.JPG
              Ace, thanks for posting that' so promptly. I'll follow your lead.
