Hi all, my first post several weeks ago concerned my new Stag and the splutters it developed when warmed up.Thank you all for the advice I recieved but after checking the timing, (3 degrees advanced) fitting a new fuel pump and the already fitted plugs,leads, coil, distributor cap and rotor arm the annoying fault still persisted. The only thing left now was the Lumemition optronic ignition,which from surfing the forum appeared to generally work or not work at all. After much more sleuthing I found some posts about problems members had experienced with their Lumenition so rather tham spend almost £200 for a new system I purchased and fitted a Power Spark kit for just under £40 delivered.
The Stag now runs superbly and I am at last able to enjoy the Stag experience and that V8 sound track, so lesson learned , Lumenition can work but can also cause problems !! Cheers everone. Jusdrew.
