When engaging 1st gear to take off from stop, I cant shift smoothly. The car judders. Shifting into any other gears, I don't have this problem. I have a longer gearbox nose, new clutch release bearing. New cross shaft bushes, new clutch master and slave cylinder. Does anyone know what could be causing this?
The other issue. On occasions I can't engage reverse. I know the reverse is a simple gear, but it seems it doesn't want to slide in. To get it to slide into reverse, I shift the lever into 1st and then reverse. On occasions, if this doesn't work, I engage in 1st, move the car a bit, and then engage in reverse. Does anyone know what could be causing this?
Some history about this gearbox, I took the best parts out of two boxes and build one, but kept the same matched set of gears. However, I might have used the best looking single reverse gear.
Sujit
Sujit
