No gaskets from the factory. but folks are making them. I had the faces of my exhaust manifolds belt sanded by my machine shop. A thing to consider, they act as a heat sync and I suppose help draw heat away from the block. Adding gaskets can prevent that.
Sujit
The first time I did my heads I didn’t use exhaust gaskets and the manifold joints leaked. The second time I did my heads (40,000 miles later) I used gaskets and they’ve been good since…..
The gaskets were supplied because people asked for them. (Not original fitment) No gasket used at this joint.
Mostly it seems they are made from a material that relaxes & causes leaks once the clamp load is lost.
I used gaskets when I fitted stainless manifolds. The heads were off to do the head gaskets. One blew after a couple of thousand miles. It would be the RH side, which is a real PITA to change in situ. So far, this one has lasted much longer….
