can anyone help with identifying what goes where please.
There seems to be three separate wiring looms suppling wires to the transmission tunnel.
The largest loom serves the interior light switch via a socket and has two other sockets for the window regulators, it also carries the wiring for the overdrive switch (Yellow/Yellow). what are the other wires in the loom for?. One sheathed grouping paired; Red/White striped and Black. There is also a single wire Blue/Black striped.
The second loom carries a Red wire for the power supply to the radio. There is also a metal cylindrical device with an internal green warning light, White/Green striped cable and Black cable already fitted. the other cables in this loom are; two Green/White striped cables connected together and Black, a Purple and Black pair, a Purple/Red stripe and Black pair, and lastly a single Red wire attached to a metal bulb holder.
The third loom has one Purple/White striped cable and Black paired, then a triple grouping of Green/Yellow stripe, Purple/Blue stripe and Green/Grey stripe, the only other cable being a single White/Blue stripe.
any help and advice would be be appreciated, and I can post images if that would help.
