With Accuspark, Bosch red coil and ballast resistor, I was getting occasional light misfire at moderate revs and increase in throttle. But this was not all the time - for example, on the run up to the Silverstone Classic from home in Bournemouth, no issues. On the run home, it played up for a little while (lumpy slow acceleration from 70), then was Ok again. On Friday, it got a lot worse while I was out, very rough running, eventually stopped and would not restart. Not in a good place to work on the car, so got recovered home.
I test my ignition with an old-fashioned timing light, which has no external power supply; it has a red discharge light and it connects with 2 leads directly into a plug supply. If it flashes brightly, I have a good spark. Its leads are long enough to place it in front of the windscreen so I can see it when I am turning the ignition key to start.
Turning the engine on starter with timing light on no 2 plug - no flash
Then tested with one lead on a spare plug fastened with a cable tie to the front lifting eye, and one end in different places. First at the coil king lead socket - good flash. Then on the other end of the king lead - nothing. So, fitted an old spare king lead, car started instantly, ran smoothly, great. Plug lead set was 'green leads' from JP in 2014 - done about 11,000 miles.
Left it running to warm up and went in the house. Came out a few minutes later - it had stopped and would not re-start.
Went through a load of tests again, got to the point where the light showed a strong flash when connected between no 2 plug lead and the spare plug on the lifting eye, but only a weak flash when connected to no 2 plug. Swapped the plugs just to check, but still good on external, not on the one in the engine.
Now running out of ideas - tried a spare Accuspark - no different. Tried a spare distributor with points - no different.
Tried a spare coil (an old Lumenition one - previously discarded because it seemed to misfire when hot) - strong flash from the timing light on no 2 plug and the engine starts and runs OK. Hooray again, till the next problem turns up!!
I have had a history of coils appearing to give a light misfire under load when hot - proven by swapping quickly for a spare cold one from the boot.
Now, I have had a king lead fail, and within five minutes of replacing it, a Bosch coil fail (but only a 'marginal' failure because it will still generate a spark if the plug is not in the engine).
I have had similar light misfire problems with a Lumenition system (that was not the classic total cut-out from the 3 pin plug problem).
Any ideas what is behind all these ignition component failures?
By the way, I have a collection of different distributor caps and rotor arms - none of those behave differently. Once before when trying to chase down the problem I swapped the points and Accuspark between the 2 distributors - again no difference. I have recently fitted new plugs, but the old one behaved exactly the same in tests this weekend. All plugs gapped at 25 thou.
I will also post on Facebook Triumph Stag Fan Club, so those of you on there don’t need to reply twice.
