Hi, I have finally got the car going, next step is rolling it out of the garage. I have bled the clutch somewhat. But I tried to put it in gear but to no avail. Tried reverse but it was crunching and grinding so gave up.
Where do I take it from here? Its a new box supplied by Robsport which the PO's mechanic fitted. I put in a new slave cylinder and the stainless steel hose, new fluid and blled the slave whislt it was bolted on.
Your help will be most appreciated.
Also does a Header Tank purge the air lock itself?
