Engine spinning well now, now looking at fuel pump that doesn’t pump. 30 years ago if I didn’t start it for a week I would always have to knock the pump body to get it pumping, this time I’ve given it a few good taps but nothing. Taken it off and put power to the terminals but still nothing, had it to bits all nice and clean inside but motor end looks unserviceable. Is there anything to do or is it a new pump? It’s the original 1972 type.
Wake up stag
Originally posted by wilf View Post'72 Manual O/d Saffron Yellow
Progress. I thought the pump was a sealed unit until you advised me that you can get inside, so then I read the instructions !!! Once I cut the tape off all became clear. I cleaned the points and it pumped away after a push start at the bottom plunger thing. Trouble is the thick bit of black plastic disc that everything is mounted on is cracked in 2 places, can’t see this bit on rimmers repair kit, it’s the only bit I need. I suppose a bit of gorilla tape will be ok to reseal the body?
Looking at areoline pumps on eBay £40. Fits stag, any good?
