Hi All,
I have been running with a wide-band air fuel ratio (AFR) gauge for a while now. I also have an ignition controller that allows control over timing versus both revs and vacuum. I am using the standard ported vacuum off the stroms at the moment. What I find it that for peak economy at light throttles (so cruising along the flat at 50-60 MPH) an AFR of 16.5 works really well with very advanced ignition(45 degrees total at 2000 rpm). My problem is, when when I open the throttle, the AFR actually goes up to about 17. The car runs fine and feels powerful, but cannot be generating maximum torque and power for the revs. Most references state that the AFR should be less than 14.7 (stoic value) for peak power. So I was going to re-shape the Strom needles to get richer mixtures for wide open throttles. So my question is, has anyone checked this on a rolling road? i.e. varied the mixture and timing until peak power was reached. If so what are the optimum AFRs and timings for peak torque? I am mainly interested in "normal" driving revs, say around the peak quoted torque value of 3500 rpm. I would then at least know what to aim for!
