Indicators
    Indicators
    Hi, I have been busy wiring up the front and back lights. Found several faults and fixed them...... really happy with that, used a multimeter which I am getting used to. The multimeter as you know is a fantastic tool!
    Tomorrow I have to fix the indicators. I could do with a head start.
    When I flick the indicators on they are on all the time......all four except the front side ones. When I switch them off and put the hazards on, all four work.....they work as they should on and off at least with a seconds interval more or less but not the front sides. I cannot hear the indicator tick tock either.
    Jbuckle suggested the flasher unit might be faulty......whats your opinion please.
    I would appreciate your expertise.
    Sounds to me like the flasher contacts are burnt in the closed position (on) Wattage needs to be correct in all 6 indicator lamps too.
    modern flasher may help, but requires a new earth connection usually.
    Iirc the hazard is working because it’s a separate flasher unit. (However that ‘indicates’ !!!! That the wattages are correct)
      As you " indicated ", I have orderd the Ldparts flasher unit.
        If you have changed to led's you need to add a resistor to each side of the indicator circuit or fit a suitable flasher
