OK so the car is all painted, mostly all put back together apart from the seats which are being re foamed and recovered. So I thought I would replace the heater valve and check for leaks before the new carpets go in, guess what :X.
So dash is out completely, four bolts are removed, heater pipes are off but will she budge ??? Not sure if I need to drill out the 2 small rivets at the front of the heater that attaches the thin plate running under the heater, I'm thinking this may be attached to the bulkhead somehow. The heater is loose but not free to move if that makes sense.
Anyone done this ?
Anyone done this ?
