Cylinder head rebuild
    Evening all,
    So my heads went off to the menders today and now i will be sourcing part/gaskets for the rebuild.
    The question i have is regarding the water pump gaskets and how many should i be using. Mine is a 12 vane pump. looking at the Rimmers "how to video " our friend Hans ( Demonstrator ) used 2 x 20 thou gaskets, Can any one who has done this before tell me is it ok to put two 20 thou gaskets anyway or should i measure the gap to see what the gap is.
    I eagerly await your answers with anticipation,
    Cheers Mike
    Refer to the ROM section 26.50.03 paras 14 & 15 for the correct procedure to select and install the water pump cover gaskets.
      Use blue tac or similar to check the gap.
        thanks all
          Hi mike did you see my message in the your messages?
