Anyone ever fitted stainless steel exhaust manifolds?
My friend fitted a set to a Morgan and eulogised so much about them that my wife (in secret) bought me a set for my Stag. Big mistake.
After several months I decided to have a go.
I was dreading fitting them, anticipating the problems due to the lack of space in the Stag., eventually, with the left hand set as they looked the easiest. The elbows are supplied with a set of stainless studs and brass nuts. 3 are fitted at the top and 4 at the bottom (nightmare)
After jacking up the car and getting restricted access to them, I found that 2 of the originals were missing. I couldn't locate the elbow onto the studs as there was insufficient space. Eventually I managed to get the elbow to fit by putting the underside studs in afterwards. one side done.
I have so far failed to fit the right hand elbow.
When I purchased it, there was a massive dent in one of the ports so I sent it back only to discover that the replacement was the same. I now know why. The steering shaft interferes with the elbow and without this dent we have a major foul. It proved necessary to loosen off the steering rack and remove the steering shaft as it was impossible to locate the elbow at all. Same problem as the other side. Studs no good, so I tried to fit the old bolts but they were too long and had to be sawn down to get access.
Having done all that, I still can't get the bolts to locate.
Can anybody provide advice/solution to my problem please?
It has been suggested that I need to take the engine out to do this job properly. Bit reluctant to do that.
John Lever
John Lever
