Hi All - can anyone help me with a printable copy of the wiring diagram for a 1975 Mk 2 Stag for a) the hazard warning lights switch and circuit and b) the fasten seatbelt wiring and circuit. Any help much appreciated. All the best.
Wiring Diagrams
Hi Johnty and welcome aboard sir
Check Grampian Stag website here http://grampianstags.net/wiring.htm for wiring diagrams
The Haynes manual and ROM have excellent wiring diagrams for all flavours of stag. What is the issue that you are trying to fix?Stags and Range Rover Classics - I must be a loony
Thanks Richard will check it out. Brought the car 5 months ago, it’s got some issues with the wiring not working probably due to age. The hazard warning switch doesn’t appear to work so I need to check out the wiring first before replacing the switch. Same issue with the fasten seatbelt light.
3 quick checks…
1:- the flasher unit on a mk2 needs to be in its clip above the column in order to work.
2:- the seat pressure pad connector under the carpet needs to be connected…. Often overlooked.
3:- the seat belt catches must have the wiring for the warning lamp to work properly…. Often swapped for un switched items.
Here's the info for the hazards - pretty sure I downloaded this from Grampian Stags' website.
- Likes 1
