Just noticed brake fluid level has dropped on the rear section of the reservoir and brake fluid dripping off the bottom of the servo.
So it looks like a replacement master cylinder is required, should I remove the servo at the same time to check for fluid inside?
Both servo and master cylinder have lasted for 21 years using Automec silicone fluid, so cannot complain.
I have read that replacing the seals in the master cylinder is a difficult job and does not last long, is it better just to buy a new replacement as they still seem to be available?
How difficult is it to replace both with a BMW unit, what model BMW do replacements come from? Is it worth it?
TIA.
Andy.
TIA.
Andy.
