identify a noise
    identify a noise
    I'm trying to find out what noise i have
    Driving along normally if I take foot of gas pedal and put it back on slightly. Its like a bearing or something is loose noise .
    Any ideas
    So hard to guess it is an impossible task to diagnose from your description.
    But noise with power on / off I would start looking at the prop shaft & quill shaft.
    then move to suspension. Perhaps engine mounts.
    But then there is always the bottle of wine rolling around behind your seat that might be the culprit.
    Alan
      Richard,
      Is the noise coming from the engine compartment or from underneath? If from the front, little end bearings, piston slap and possibly big end bearings can produce a "rattle" under the onset of very light torque. The propshaft splines tend to align the propshaft under increasing torque so the lower frequency shake from the transmission can reduce as you put your foot down. More info on direction and type of noise would help.
        thx .its coming from underneath rather than engine side .seems prop diff area
        it had a recon diff and new cwp about 3 years ago.
        suppose I'll have to get under there see if I can see something
