Tappet/Pallet Shims
    Tappet/Pallet Shims
    Hi,
    I have been checking my valve clearances. When I measure my Tappet shims using a digital vernier calliper the sizes vary between .061 and 091 thou, which seems thin when I compare them with the replacement shims sizes which seem to in the range 0.090 to 0130 thou.
    Am I doing something wrong or is it normal to have shims/pallets of this size? If it is normal where do I get shims of this size?
    Also is a digital vernier caliper accurate enough to measure the shim or do I need to use a micrometer?
    Thanks in advance
    Chris
    1977 Tahiti Blue TV8 MOD
    James Paddock do tappet shims starting from 70 thou
      Also Look at lotus and SAAB. They use the same shims..
        A vernier is also referred to a a very near.
        An imperial micrometer is recommended.
        A high quality digital caliper e.g. mitutoyo would work though, but they typically cost quite a bit more.
        Usually if the heads need less than an 85 thou shim it’s because the seats have worn & been cut deeper.
        Beware of grinding down valve stems or shims too much. They may be too soft after more than a few thou is taken off.
        2.
          I use a ball-ended Moore & Wright Imperial micrometer to measure shims. There's often a depression in the centre of the shim where it sits on the valve head and it is important to measure the actual thickness at the point where the shim operates. A vernier caliper will give you an approximate result.
            micrometer every single time for me, vernier will give you an approximate size as has been said ^^^
              My Dad was an engineer and had a lifetime of measuring tools when he retired. Even though many went to the apprentices, as was tradition, I got a few and this dial gauge was perfect for those shims..
                That's a knuckle duster which measures the strike force.
                  Been doing mine, Rimmers dont do thinner sizers but Robsport do.....
                    There's a chap in the Hillman Imp community does some very thin shims. Don't remember his name but my engine has a few in there!
                      Hi
                      Thanks for all the replies.
                      All sorted now, I bought a micrometer and ordered the shims from QED Motorsport. (I was extremely pleased with their service) The shims are available from 0.060" in 0.001 increments.
                      Chris
