Carb petrol overflow pipes
    Hi all, do the petrol overflow pipes use clips to secure them to the carbs ? may be a silly question but mine are just push fit and i cant find any references.
    When I fitted out my carbs, I googled Stag engine bays and had a look at several engines. Non of them had clips but rather they were held on by these adaptors.
      Those adaptors are for the crankcase breather hoses.
        Oh, sorry I thought they were... I dont understand....why are they showing forcthe overflow and breather pipes?
          I got a pair of those things for my breather pipes and they didn’t fit, too small to go over the fitting in the carbs.. didn’t think to try them on the vent pipes which are smaller diameter.. I just used appropriate sized fuel line for those.. I didn’t use any clamps as there is really no pressure involved, it just dumps to the floor (or charcoal canister in my case)
          For the breather pipes I used some short pieces of fuel line that nicely fit the carb stubs and the OD was a perfect fit for the breather hoses.
            Overflow pipes
              I could never see how the overflow on the right hand side could work as it is routed over the top of the carb elbows. Having once had my air box fill with petrol I rerouted mine underneath.
              Nigel
                Nigel
                I think that is just another example to add to the list of cock-ups in the Triumph publications, and I hadn't noticed it before. As others have said, the overflow hoses just fit straight on to the carburettors.
                They are principally vent pipes from the float chamber, in which case the raised position doesn't matter, but as an overflow, you re routing seems a very sensible idea.
                MIke
                  The only problem is , if like my petrol overflow pipes, they are not very new and are a bit hard and brittle,so if like my stag the float has stuck then the excess fuel has to go somewhere.It should vent out and on to the floor but mine came straight out of the carb squeezing between the rubber pipe and onto a hot engine. I think i will go belt and braces with new pipe and clips so that should never happen again.
