Hi all,
just removed my radiator. The bottom fixings don't look stock. It's an rv8 conversion so could be because if this. There seem to be 2 studs at the bottom of the Rad that look like stock fixing. But the Rad is mounted using separate studs at the rear of the bottom of the Rad. These fit through holes in tabs that in turn are bolted to the rear of the from valance. Photos below. Anyone got photos of the correct mounting or is this correct ?
tim
tim
