Capiilary water gauge
    Hi All
    I am considering fitting a capillary water gauge to our Stag. Can anyone advise of a source of a suitable gauge, preferably one where the needle faces downwards so as to match the other mark 1 gauges.
    Bruce
    I run a combined capillary oil pressure and water temp guage, with a IMG_4654.JPG 0 to 60 psi scale for the oil pressure (which is more suited to the Stag engine IMHO). Unless memory fails me, I got it from Holdens. Water temp pointer is downwards.
      Me too, mines the same combined unit as fitted to the MGB and at normal temperature it will be pointing at 6 o’clock
      Try MGBeehive for a similar one..
        I got mine from MG Beehive but you also need an adaptor to take up the thread
          Did you paint the bezel or could you buy it Black?
            Does anyone know of a gauge just for water temperature rather than a combined gauge as kindly suggested above?
            Bruce
              Bruce
              Expensive but with chrome outer.
              https://www.moss-europe.co.uk/gauge-...-lusib422.html
              They got a few but don't know of their quality...http://www.minispares.com/product/Classic/TIM005.aspx
                Alacrity - I actually bought it black, but that picture was taken during the process of spraying all the rest to match.
                  Can see it is available in black any more but I could paint it to match the standard MK2 gauges. I wasn't going to have an oil gauge (worry gauge!) but this this Lotus 60psi one looks OK.
                    I run full scale, full sweep water temp, oil temp and oil pressure gauges.
                    Cheers Ian A
                      I have not seen a mechanical temp gauge which looks similar to the other Stag Mk1 gauges.
