Can anyone advise the possible cause and solution the the following. I have fitted new reconditioned engine and completed 2000 mile with no issues. 10 days ago the car was running good but as I went to park the engine sound changed and eventually stopped I immediately thought the SU pump the issue & fitted new electronic pump. The issue continued, symptoms as follows;-
> On my first journey the car sets of great starting first time And for first 1 to 2 miles running good then the engine sound starts to change and gradually stops it will eventually
> Start again ok but the same thing repeats. After a few attempts with the same results when the car stopped we immediately
> removed the engine side connection from the empty filter this was obviously under pressure as the fuel in the pipe sprayed out.
> Following further attempts, checks revealed that in each case no fuel was in the filter when the car stopped.
