Whilst it is off the road I thought I'd try to 'repair' my steering column so that it can be moved in and out.
Eventually I've needed to dismantle it down to the component parts - squirting PlusGas and Silicone spray down the pipes didn't make much difference.
I've now taken the 2 'rubber' o-rings out and given everything a clean etc.
I've even trimmed the flash off of the o-rings but on reassembly the 2 pipes still need a lot of force to slide them up and down.
Liberal amounts of silicone spray help but there is still too much stickiness.
The o-rings are obviously non-original and I would assume that buying new will just deliver 2 similar parts.
Anyone got any tips on how to fix this?
My first thought is to cut some of the o-ring off, to reduce the width and thus the surface area of the sliding bit.
