Cost for Engine/Gearbox Removal/Replacement
    What would owners consider a reasonable cost for a garage to remove and replace a Stag engine and gearbox? The Leyland Cars Repair Operations Times book states 8.95 hours for a manual Stag and 8.65 hours for an auto. I have just found out that a local club member was recently charged GBP2500 to do just this plus separate the two main assemblies and put them together again after engine rebuild. No strip down; the engine was sent elsewhere for a rebuild and this was charged separately.
    I reckon £100 an hour is not unreasonable, so a Stag ‘specialist’ should be able to do the job to the book times, so £900 plus VAT (£1080 inc.) should cover it unless there was extra work to do bearing in mind that our cars are a little older than when the ROT book was complied.
      I would be nice to have a guide in the technical section on fitting and removing an engine....,
        It’s all fully detailed In the ROM
          Why pay top rates for a specialist when it is not a specially skilled job?
          Chris
            Some people do not have the necessary skills, equipment or time, so have to resort to so-called specialists. Unfortunately, sometimes specialists take advantage.
              Looks to be £200 an hour, perhaps they didn't want the job but the customer said yes.
                EJ Wards charge £60 an hour so £648 for 9 hours labour including VAT. Worth a chat with Mick to discuss.
                Dave.
                Expert:- Ex is something that has been and spurt is a drip under pressure.
                  They are out there unfortunately Dave.
                    Not a skilled job but very heavy job with lots of risk to brake lines and paint.
                    Not a job that I enjoy doing, but would at £2500
                      Get mine done for £700 out and back in
                      Stag Owners Club Forum has registered Tonywhite as a Trader in used parts for The Triumph Stag. 13.12.2017
                        Done it a few times. It’s a day to do carefully, maybe two days to get running, or get a list of reasons why it won’t a cheap job will cause more damage than it’s worth.
                        1st job I did on my house was to fit a washing line. Second job was fit a 1.5 ton pellorby joist in the garage for lifting engines
