Windscreen chrome trim
    Hi
    Does anyone know of anyone who can fit the chrome trim around the windscreen? I’m near Reading.
    Not too bad a job to do yourself, i used a small allen key extended with mole grips, put the trim into place push the Allen key under the rubber lip and twist, it pushes the rubber over the trim lip then move along doing the same, took me an hour on my own
    Alan
      Alan
      Hi, Could you please elaborate, will appreciate.
        Was going to make a proper tool but this worked well, tried fitting the windscreen and trim together but trim fell off so had to do it afterwards
        Alan
          When ive fitted the chrome trim, i use rope under the rubber to lift the rubber flap then slide the chrome trim in the gap
