Hi all, Iām going to replace my sump gasket in situ, whilst not having oil pressure problems, no knocking, oil light goes out straight after starting etc, I was wondering if it would be wise to pull a bearing cap to check the state of the shells, if it aināt broke donāt fix it?
Also wanted to check the chains, looking from the rocker cover, the adjusters only look to be 3/8ā out?
Iāve only had the car 3 yrs & canāt find much history apart from when it was tested in 05 mileage was 13k, I bought it in 19 with 16k, now on 22k with no engine problems apart from oil leaks.
Paul
Paul
