Recently fitted an external water pump. It only has 2mm or so clearance from the cooling Fan Blade.
The fan kept clipping the pump shaft and I needed to trim the blades, but was not confident of a permanent fix.
I decided new a new fan was a good bet and ordered one from SOC spares. ( The fan is not cheap!!!)
WOW, they are built well and solid as a rock. My original one was quite flexible and the new one is not!!!
Looks great and as long as it fits it should sort the problem out.
Just a note to anyone worrying about a fan with little clearance and needs a well built solid unit. ( no affiliation with manufacturer)
