Hi All
I have been busy sorting out the electrical wiring on my 1975 Stag and am having difficulties getting the hazard and turn indicators to work, I suspect it is the relays. Could anyone answer the following questions:
1. Rimmers Parts Catalogue shows the turn indicator relay on the bottom left of the relay board behind the parcel shelf and the hazard relay on the bottom right of the relay board. However the hazard relay is not on the relay board but is behind the dashboard and is round in shape, is this correct?
2. Which relay is located where, as when I look at and trace the wiring behind the dashboard there is a light green with slate stripe wire which comes from the hazard switch and a light green and brown stripe wire which goes to the turn indicator stalk. When I look at a wiring diagram it implies that the wires above are for the turn indicator relay and not the hazard relay, is this right, as the Rimmers Catalogue must be wrong?
Any help would be appreciated in clearing up which relay is which and where it is positioned.
Johnty
Johnty
