Hi All
My new Mk 1 Stag had the suspension rebuilt by the previous owner. However, the front ride height (centre of hub to bottom of wing) is 15.5", whereas the back is 14.5". From reading here the 14.5" is correct.
I found a receipt for a standard length front spring (215518) from a usual trusted supplier, so I can't figure out why it is so high on the front.
Is it because it is new? Is there anything other component(s) that would cause the ride height to be too high?
If I switch to 1" lowered progressive from Wards or Monarch will it end up being too low?
Jeff
Jeff
