clutch query
    clutch query
    Hi all does anyone have any info or experience of the modified clutch release bearings? The Bros bearing has a flat bearing surface and LD has a more pronounced curvature than standard. Just wondering which may preferred and why.
    Thank you in advance
    Niall
    A bearing with a flat surface is never going to seat properly against the fingers of the clutch plate. The LD one is the correct shape and essentially similar to the original bearing.
      I would avoid the heavy duty Koyo bearing sold by a few of the suppliers. It’s much stiffer to turn than the standard one, and mine started making a lot of noise where it was rubbing on the pressure plate fingers. This would eventually result in the fingers wearing leading to failure, so I fitted a pull off spring to minimise wear. There’s a lot of information on the Buckeye Triumphs website.
      Nigel
        Flat to curved is ok; curved to flat is ok.
        Peters is probably the best source though.
          Just surmising, but with a flat surface (bearing), against a flat surface (clutch fingers), isn't the contact radius going to be indeterminate? This is going to cause chatter (dont we already get enough of that from the passenger ).
          Chris
            Exactly! A cover with flat fingers must have a curved bearing surface contacting them.. On some clutch covers the ends of the fingers are raised in to a "Dome". This type will need the bearing with a flat surface.
              Thank you for all responses
                Yes I forgot about that type with curved fingers Mike. As you say needs a flat faced bearing in that case.
                Chris
