I have had to set to and renovate the water pump on my Stag after a tiny leak turned into a torrent. All went well with the initial disassembly, but now, well, I am stuck.
Today the post finally arrived with the slide hammer adaptor I was waiting for.
So I duly commenced slide hammering. With gusto. To the point of aching arms etc.
And......................nada, nothing, nowt - the pump has not budged, not one little bit.
I considered getting some tension on it via a rafter and a ratchet strap, then "persauding " it with an air chisel, turning the impellor in the direction where the skew gears would force it out. But that seems a little drastic and not exactly sympathetic to the jackshaft gear, so I post here in the hope of alternate, and maybe kinder, suggestions.
NB - I have no materials, no welding kit, to make up "special things".
I post a pic of the adaptor and the slide hammer I used, (with my hand in view for scale) so you can see I am indeed using a bit of kit that should have more than enough oomph. At one time I found some sash cord (doesn't stretch) and employed a large sledgehammer in a double loop of it, lifting it upwards as fast as I could, in case more heft was needed - nothing.
Suggestions (no, not rude ones please)?
