oil build up between heads
    Mk 2 Stag (38k miles) running well but oil building up between heads. Is this the beginning of gasket failure?
    Water pump oil seal most likely.
    You need to try & identify the source though before dismantling anything.
      Or running down from a cam cover gasket, one of mine is currently doing this.
      Give it all a good clean first and find the source of the leak.
        Many thanks for suggestions. I have cleaned up the oil and will see what happens. The water pump oil seal would be a good result!
          [QUOTE=mutley;n834845. The water pump oil seal would be a good result![/QUOTE]
          The cam cover gasket would be a much better result! Much less work / hassle. Clean & dry the V area, and use talcum powder to trace the source of the leak. Start with the easy stuff first; don't immediately assume it's the worst case.
            Chalk is another good way as the oil stains the chalk line where it runs across, the same a water based felp tip on masking tape for water leaks in the car.
              Talcum powder it is then. Thanks again for alll the great suggestions. Happy Easter to all
                did you identify the leak yet?
                  Is it manual or auto?
                  I have seen oil in the vee from an auto kickdown cable
